Wireless Sensor Networks
Microseconds delay to control digital outputs in WSN-3202
I’m using the LabVIEW WSN Module to control the digital outputs of the WSN-3202 node. Is there a way to add a microseconds delay in my flat sequence structure? Because I’m using a pulse driven optical sensor which requires delays intervals in microseconds.
Ahmed
(5,800 Views)
Hi Ahmed,
The availability of a microsecond resolution for timing depends on the onboard clocks or setup that the system allows. These nodes are often used to control/acquire in a non-continuous way to save battery. Therefore, they are required to wake/sleep in cycles that take a couple of minutes generally. What are you exactly trying to do with the node?
(5,774 Views)
