Wireless Sensor Networks
NI wsn nodes programmable using nesC?
Anybody, Can you please tell me whether the NI Wireless sensor networks be programmed using NesC (Tiny OS)? If so how?
(8,711 Views)
Accepted by topic author cranian
Hi cranian,
No, as you said, NesC is used to program WSN nodes that are running TinyOS. NI WSN nodes are not running TinyOS, but a firmware image optimized for measurements and long term battery life.
Using LabVIEW WSN, you can customize this personality to add analysis and decision making. See this white paper: http://zone.ni.com/devzone/cda/tut/p/id/9006
If you have existing algorithms written in C, you can place your C code directly inline with your LabVIEW code.
Kurt
Message Edited by jkurtw on 03-04-2010 09:43 AM
(8,707 Views)
Thanks Kurt
(8,699 Views)
