Wireless Sensor Networks
Node disconnects when other nodes are connected
Hello everyone,
I'm using a 9792 gateway with 6 various nodes connected in a star topology. With 6 nodes, everything is working fine. The problem arose when I tried adding two extra nodes. These nodes I was able to connect, but since then, one of the previously existing nodes cannot stay connected and keeps disconnecting. Has anyone seen this issue before?
(6,662 Views)
Hi bpopa,
i AM ALSO USING THE KIND OF SIMILAR SETUP WITH MANY NODES
try this:
1. Close the MAX and open it up again, if it not works delete all the nodes and select the proper channel and start adding the nodes again. lets see if it works.
2. Reset all the nodes and try.
3. Resest the gateway.
Thats all you should try hope this works, i think there should not be any problem because gateway in a star topology can connect to eight nodes ata a time.
thanks.
(6,656 Views)
