Wireless Sensor Networks
One wire digital sensor on WSN 3230?
 Hi all
I had a WSN 3230 and it have two DIO. Can i connect DS18B20 to DIO point?
Andy
(8,694 Views)
Hi wcchung33a,
yes you can connect the DS18B20 to the 3230 node. just make sure the resolution of the ADC id enough to take the readings from the sensor as well as check whether the DIO's are general purpose DIO.
thanksSmiley Happy
(8,692 Views)
i want to find out the meaning of the code
if (cluster -1>=1) specially when they are trying to connect cluster members with the cluster head in a given cluster
(6,485 Views)
