Wireless Sensor Networks
Problem configuring WSN network in MAX
HI,
I am facing this problem suddenly in using my NI 9792 gateway .The module is getting detected in MAX  It is that I am not able to find the Node option under devices and interfaces of the gateway in MAX. I am using LV2010 and NI WSN 1.2. Correspondingly even from LabVIEW Web servies application I am not able to add  nodes. I  formatted the controller and dumped the software multiple times. I check my licences all are active. I cannot make out what the problem is. Sometimes I also get VISA error under Devices and interfaces.
There Isn't any driver compatibility issue . Because i have worked with the same setup before.
Can someone help me understand what the problem is?
(6,570 Views)
In the format this time was better . WSN is visible under devices and interfaces but VISA error still exists.  Nodes getting added from LabVIEW. NI WSN error.jpgVISA errror description.jpg
(6,569 Views)
This is a duplicate post, please add further posts to this forum.
Note: The VISA error could be solved by looking at the following KB.
Corby
(6,559 Views)
