05-09-2013 10:40 AM
Thank you Brian,
If it's possible, could you post a note here when the solution will be available. This way it will pop in my emails and I'll mark the post as solve.
Thanks again
Mathieu
05-09-2013 10:42 AM
As soon as I verify a solution I will post back and send you the solution.
Cheers,
Brian A
R & D Product Support Engineer | WSN/Network DAQ
 vgravel
			vgravel
			06-06-2013 06:52 AM
Any news on that issue? I'm running into the same problem...
Thanks!
06-12-2013 10:59 AM
Mathieu and vgravel,
Please check your Private Messages.
Cheers,
Brian A
R & D Product Support Engineer | WSN/Networked DAQ
 vgravel
			vgravel
			06-13-2013 09:47 AM
Hello Brian,
I'm answering you here because we cannot add attachment in private message (?).
I did like you suggest but still get the same error ("Server does not support remote panels").
I attached a zip file with all the config that I could think that would be usefull. Maybe I'm missing something or the error is related to something else?
Thanks for your help!
Vincent
