Wireless Sensor Networks
Time and date on x-axis for chart or graph (for 1 hour sample interval)
I configured the WSN-3202 node’s sample interval as 3600s (1 hour). I need to use a chart or graph to represent my data where the x-axis shows the time (if possible date also) at which each sample was taken.
Ahmed
(5,911 Views)
Hi ahmed,
I think you should right click the chart>>properties>>Display format and select Absolute time if it shows and configure the settings shown on the right side in display format dialog box. if it is done then your chart shows the time, if not then you have to do a littele bit of programming.
Warm Regards.
(5,900 Views)
