10-29-2009 04:53 AM
These wireless sensors are great and now I'm trying to find different application uses for them. Is is possible to get the sensors to work with Touch Panels... more specifically the TPC 2106
Solved! Go to Solution.
10-29-2009 08:52 AM
Hi JChec,
I am glad you like the new WSN measurement nodes!
Yes, you can access the WSN I/O on a TCP. The I/O variables that are used to read/write I/O are supported on Windows CE and Windows XPe.
The only thing that probably won't work on Windows CE are the WSN Host VIs, which are used to send/receive string-based user messages. If you need support for this or other advanced LabVIEW features, the newer TPCs running XPe pretty much offer full desktop LabVIEW support.
What are you using the WSN nodes for currently?
Kurt
11-03-2009 01:09 AM
Hi Kurt,
Thanks for the informative response and sorry for my delayed reply. I'm not using them in a current application, just been testing them out and trying to find out any interesting applications for them. Wanted to know about the Touch Panels to see what options I'd have for future applications.
Jevon
11-03-2009 01:27 PM
Hey Jevon,
Do you have any potential applications these can be used in? Can you share any information?
Let us know if you have any questions!
Kevin
11-04-2009 09:20 AM
Hi Kevin,
Haven't used them in any systems yet, just been using them to try work out some possible applications for them. Production line throughput monitoring is the only useful application we think of at the moment. The sampling rate is quite slow on the non programmable analog input though, but the according to the datasheet, the programable 3202 can get up to 35HZ which for most counting applicationsshould be sufficient.
Jevon
