Wireless Sensor Networks
Wireless Syystem (WLS 9163)
Hello Forum.
I am using the following equipment from National Instruments:
NI WLS 9163
NI 9219
I set 9163 as the NI WLS wireless system through an ad hoc network.
I and acquiring the values ​​of resistance (voltage with custom Excitation) of load cells wired in full bridge.
Everything works!
However, the acquisition rates are very low!
I can not get acquisitions with more than 2 Hz (high resolution)!
Will can help me on the following issues:
This is because the equipment I am using?
How can I change that with this equipment?
There is another wireless system from NI, with better results for this application?
I appreciate the help! Smiley Happy
(Not sure if this is the most suitable place, if not ask for it let me know)
(6,069 Views)
Hello Luis_ferreira,
You're wright, this is not the right place to post Smiley Wink. This is the forum for our WSN hardware.
Please copy your message in the Multifunction DAQ forum.
Mathieu P. | Certified LabVIEW Associate Developer
National Instruments France
Journées techniques : des fondamentaux aux dernières technologies pour la mesure et le contrôle/comm...
(6,060 Views)
Mathieu P.,
Thanks for the tip.
I'll make this change.
luis_ferreira
(6,055 Views)
