Wireless Sensor Networks
ZigBee
Hi engineers, I'm used the hardware WSN 9791 and WSN 3202. Exist someone hardware which amplify the signal ZigBee? Some kind of router.
Regards
Hugo Santos
Student at ISEC - Master Mechanical Equipment and Systems
Message 1 of 9
(8,101 Views)
Hi Hugo,
Each WSN node could be configured as router so if you want to increase the distance between your gateway and your end node, put another node configured as router between its.
Sincerely
David S.| Certified LabVIEW Associate Developer
National Instruments France
Message 2 of 9
(8,097 Views)
Good afternoon, I wonder if there is compatibility of your products, with National Instruments, including NIWSN9791, NIWSN3202. I need to amplify the signal ZigBee. I would appreciate an answer soon.
Regards
Hugo Santos
Message 3 of 9
(8,084 Views)
can transferring audio file is possible using wsn 9792(ethernet gateway) and 3202 nodes? how please help.
Message 4 of 9
(7,942 Views)
Hi abh,
If you want an answer quickly, post in a new topic.
Sincerely
Message 5 of 9
(7,939 Views)
okay..
Message 6 of 9
(7,937 Views)
sir, i am new to discussion forums so i won,t be able to post it new topic please guide
Message 7 of 9
(7,932 Views)
sir,
please tell me how to transfer the audio file using wsn 9792 and wsn nodes
Message 8 of 9
(7,922 Views)
You could click here and create a new message (on the top, you have "New Topic")
http://forums.ni.com/t5/Wireless-Sensor-Networks/bd-p/430
Sincerely
Message 9 of 9
(7,919 Views)
