Wireless Sensor Networks
crossbow Drivers and examples
- Does any one know the diffrence between Node and point?  I downloaded the drivers and tried to take a look at the VIs. There are multiple read sensor: Read sensor(MTS310)  Nnode-Npoints , Read sensor N nodes 1 points .... and I don't know which one has to be picked. My application is reading 2 MTS310 sensor borad on 2 MicaZ nodes.
- My other question is that, when I run the program " readhealth.vi", when I trun 2 micaz on to communicate with the gateway, I can see the data of one node gets assigned to the other senosr node. For example, in my VI, GUI, I can see NodeID: 3 but data is for NodeID 2. Can anyone explain to me why it happens?
SK
(6,232 Views)
You should probably move this to the LabVIEW forum.  This forum is specifically related to NI WSN, not 3rd party WSN devices.  You'll get a quicker response over there.
Chris
Certified LabVIEW Architect
Certified TestStand Architect
(6,078 Views)
