Wireless Sensor Networks
ni wsn/labview
Hello
For my project i have to figure out how to establish the communication between node 1 and node 2 without the use of the gateway as an intermediate (3 or less hops).
Can you please tell me how to wire the components in the figure below ?
Thank you !
(8,701 Views)
WSN signal routing is abstracted away from the user. Built on the ZigBee protocol, the WSN network provides message hopping and adaptable routing.
For a LabVIEW example using WSN nodes, you can navigate to the following folder: Help >> Find Examples... >> Hardware Input and Output >> NI-WSN. In this Example Finder folder, you can find many examples of WSN applications and how code for these applications is designed.
(8,689 Views)
thanks for helping 🙂
the problem i had at first was configuring an end node to be a router node, now the problem is solved, i did it using NI MAX
(8,662 Views)
i need to know how to pass from "capture2" to "capture1" i know that it can be done using "shared variable node", but when i use this option i ge t "capture3" not "capture1" !! any help please!
(8,656 Views)
Could you please clarify your question? Are you trying to pass data from one node to another?
(8,627 Views)
exactly,I passed from the star network topology to the multi-hop network topology, the point is to send data from the end node  to the router node, and from this router node to the gateway, and to do so i need to use the shared variable in labview code so that the data collected from the thermocouple in the end node can be available all through the network.
I hope it s clear enough 🙂
(8,620 Views)
(8,620 Views)
