Wireless Sensor Networks
setting time in wsn 9791
How do I set the time and date of my nodes
Message 1 of 11
(7,671 Views)
Hello Ilublessing,
Can you ellaborate a bit more on what exactly you are trying to achieve here. The WSN 9791 and the nodes do not have the capability of displaying time or date information
Will
William A
National Instruments UK
Message 2 of 11
(7,660 Views)
Thanks, I am trying to set the date and time on graphical display  and time stamp against 01/01/1904 is currently displaying
Message 3 of 11
(7,651 Views)
Hello Illublessing,
To extract the date time information you would have to use the date/time function formatted to extract the information you want using the format to string function. You can only do this in software.Both functions are on the functions palette.
Regards
Will
William A
Message 4 of 11
(7,640 Views)
The nodes get their time from the 9791.  In MAX, be sure to set the time server that the 9791 gets its time from.  When you do that, the nodes will pick up the time change on their next synchronization interval.
Message 5 of 11
(7,628 Views)
You can configure the Time Server in MAX by using a NTP server to set  the timestamp. The link below shows you how to go about setting  the time server in MAX.
http://digital.ni.com/public.nsf/allkb/44FA322FAFF8D58D862575BD00591A54?OpenDocument and this link  http://digital.ni.com/public.nsf/allkb/EA90C9FF24D9A041862575EE004ED415?OpenDocument shows you how to configure your PC as an NTP server for setting the time server.
Will
William A
Message 6 of 11
(7,623 Views)
Thanks for the solution profer, but I am still getting the old time of 1904 from the time-stamp of the node and eqaully on MAX, the last communication time of the nodes.
Blessing
Message 7 of 11
(7,608 Views)
What you could possibly do is use a public NTP server to set the time stamp for the gateway. You can choose from a pool of servers here http://support.ntp.org/bin/view/Servers/NTPPoolServers . You can use this public NTP IP address  198.82.1.204 to set your time server. Make sure you save your setitings and reboot the gateway afterwards.
William A
Message 8 of 11
(7,591 Views)
Hello IIublessing,
Have you tried using a public NTP server to set the time stamp as suggested in my last post? Did that work for you?
Regards
Will
William A
Message 9 of 11
(7,568 Views)
It didnt work but I use another method to convert the 1904 and time to current time using some VIs
Message 10 of 11
(7,563 Views)
