LabVIEW Interface for Arduino Discussions
Where is LVIFA_Base.pde for LabView 2012
007 VISV Getting Started With the LabVIEW Interface for Arduino states that LVIFA_Base.pde is located in C:\Program Files\National Instruments\LabVIEW 2010\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LVIFA_Base.pde.  I'm using LabView 2012 and there is no Firmware directory and I can't locate LVIFA_Base.pde.  Any ideas?
Message 1 of 39
(48,366 Views)
I don't have 2012 but I would probably uninstall LIFA then reinstall and see if that fixes anything.  Otherwise, here it is for 2.1.1.69.
Message 2 of 39
(9,981 Views)
I upgraded my LIFA to 2.2.0.78. I use labview 2011. I can't locate LVIFA_Base.pde either.
I downgraded to one of the older versions and Firmware folder came back.
Message 3 of 39
(9,981 Views)
I had the same experience. When I upgraded to LIFA 2.2.0.78, there was no firmware folder and I could not find it. However, NathanB posted LVIFA_Base_2.1.1.69, we can, now, use it.
Thank you NathanB
Message 4 of 39
(9,981 Views)
I hadn't realized there was a newer version of LIFA when I posted (it's not in VIPM).  Are you saying that the 2.1.1.69 firmware works with LIFA 2.2.0.78?
Message 5 of 39
(9,981 Views)
When I ran VI package manager, it detected automatically newer LVIFA, 2.2.0.78. That is why I could update it.
I tested a simple example analog signal read thing  with 2.1.1.69 version. That worked well. Anyway I will go through,  but if I have a problem I will post it. Thank you.
Message 6 of 39
(9,981 Views)
I just installed the latest version.  According to the description, the older firmware should be fine, you just won't be able to use the new IR Transmit functions.
Message 7 of 39
(9,981 Views)
I'll fix this shortly.
-Sam K
Message 8 of 39
(9,981 Views)
I've fixed the installer and the update should go live in a day or two.  For now you can use the attached firmware.  Please post back if you find any issues!
-Sam K
Message 9 of 39
(9,981 Views)
In labview 2011 there the firmware folder and LVIFA_Base.pde!
trying to download the sketch LVIFA_Base.pde during compilation there are errors of various kinds. Will you help me?
Message 10 of 39
(9,981 Views)
