NIYANTRA Discussions
[Group M] NIYANTRA 2013:Ask Your Mentor
This is the team-mentor interaction space for all the NIYANTRA 2013 teams belonging to Group M. If your team belongs to this group,this is the place you should be interacting with your mentors.
Make Sure You Read this Document Carefully Before Starting.
This group is being mentored by Mr Chetan G & Mr Pavan (National Instruments R & D)
Click here for the Group Allocation List
(11,183 Views)
Sir,
I am one of the participant of Niyantra and would like to know how to loan hardware from NI for the project purpose. What are the hardware that you can provide and how much will it take to reach us..Presently we are in the need of a Camera as we are just starting off the project as our finals have just finished in.
(7,292 Views)
Sir,
Where should I send my project video
(7,292 Views)
sir,
In our project  we are trying to convert the labview prog to a exe file or apk file so that it runs in andriod platform in mobiles so in tat case vil it read d ouside world information from the sensor
(7,292 Views)
Good morning sir,
How i have to submit my video,that means in which section of our NIYANTRA 2013 i can upload my video.
Rahul  kumar
(7,292 Views)
Sir,
How do i generate a prbs (Pseudo Random Binary Signal) in LabVIEW 11 (and later versions) which has a frequency of 0.05 and lower value=16 and upper value=24.I can generate the same in MATLAB using the following code: u=idinput(8000,'prbs',[0 0.05],[16 24])
When using MATLAB script in Labview, it gives me only a single no. which is the lower value of amplitude instead of giving me an array of prbs between lower and upper values. For ex. by using the above command I only get 16 as output instead of getting a prbs of 16 and 24.
RAHUL MISRA.
(7,292 Views)
