FIRST Robotics Competition Discussions
Axis 206 Camera Problem
hi friends, i'm from Chile and belong to the team  #4966 (rookie team), we have a big problem with the axis camera, we have 206 axis camera model, and isn't working. the camera has been configurated like a FRC tutorial says and this isn't displaying to the dashboard. Despite this the camera appears in to the browser when we put the IP direction, please, can you help us? you can think of? thank so much. we'll wait for your  answer..
(5,585 Views)
Hey Erick,
So it sounds like the camera is working, so I'd like to confirm, do you have the vision enabled in the robot code? And if you're building the code as an executable have you set the "Vision Enabled" to true then set it as the default value?
Hope this helps!
Ryan_S
(4,597 Views)
