LabVIEW Interface for Arduino Discussions
No puedo compilar en el arduino 1.0.5. r2 el LIFA_Base.ino para el labview 2013
Buenos dias, no puedo compilar el LIFA_Base.ino en el arduino 1.0.5 r2 para el labview 2013, sale error
LIFA_Base.cpp.o: In function 'loop':
C: \ Program Files (x86) \ Arduino / LIFA_Base.ino: 59: undefined
reference to'checkForCommand () '
C: Program Files (x86) \ Arduino / LIFA_Base.ino: 65: undefined
reference to'sampleContinously () '
LIFA_Base.cpp.o: In function 'setup':
C: \ Program Files (x86) \ Arduino / LIFA_Base.ino: 39: undefined
reference to'syncLV () '
Ayudenme
(6,480 Views)
This happens when you don't get all of the LIFA firmware files opened at the same time in the Arduino IDE.  Make sure that you get all of the files to open in the tabs when opening LIFA_Base.ino (it should do it automatically when you open LIFA_Base.ino in the Arduino IDE).
However, if you are not already using LIFA, you should instead use LINX.  In LINX, you no longer need to compile the firmware.  Also, LIFA is no longer officially supported.
(4,058 Views)
Hola yo tenia un monton de problemas hasta que lo instale desde un windows XP! Y andubo super bien! Ojala te sirva! Saludos
(4,058 Views)
