FIRST Robotics Competition Discussions
Wireless control of 2009 FIRST robot doesn't seem to work !
Hello there !
                  We have a problem in our 2009 FIRST robot in terms of controlling it wirelessly through driver station.When cRIO and Driver station
are connected through ethernet port the robot works fine !. If I try connecting the robot through the router  connection it doesn't respond at all.
I checked for all the wireless settings of router and gaming adapter.Both seem to be intact as per the requirements.
Any help to resolve this issue would be greatly appreciated.
Murthy
(4,592 Views)
Is encryption still set up in the gaming adapter? When was the last time wireless worked?
It would help if you posted screenshots of the configuration of the router and the bridge so that other people can review the configuration.
(3,321 Views)
Encryption in the sense? you mean the settings or the password?.But they
were the same as per the documentation rules.The last time we used was in the month of april.Nothing has been changed since then
Murthy
(3,321 Views)
At the competitions, you had to enable encryption on the bridge to work on the competition field. If you did not remove it, it will not work with your router, which does not have encryption enabled. The fact that you say you haven't tried it since April makes me think that is the problem.
Like I said earlier, if you post screenshots of the configurations of the bridge and router, we might be able to really help you, instead of just guess.
(3,321 Views)
Thanks a ton for helping me out !
The encryption seems to be the problem that I was looking into.I actually missed that part while checking for my settings  and my settings looked like this !
That solves my problem !.I really appreciate your timely help !
Murthy
(3,321 Views)
