09-30-2010 03:08 PM
Update: This discussion applies to Issues from the 2010 FTC season and is no longer relevant for current FTC competition software.
Where do you find the National Instruments\LabVIEW
2009\Targets\NI\NXT\NXTToolkit\ website that has the sample vi's on it?
10-01-2010 12:52 PM
I'm confused by your question. Have you already installed LabVIEW Education Edition 2009 or the FTC toolkit?
10-01-2010
01:01 PM
- last edited on
06-11-2026
12:15 PM
by
Content Cleaner
The NI Training material is here: https://forums.ni.com/t5/FIRST-Tech-Challenge-Documents/FTC-2010-2011-Training-Material-Archived/ta-...
My company also has comprehensive FTC training materials here: http://ftcmastery.com/
10-01-2010 02:39 PM
I have installed LAbview 2009. Not sure about the toolkit. The problem is,
I'm reading the Getting Started document,
http://decibel.ni.com/content/docs/DOC-7204, and there are frequent
references to sample vi's which can be found by navigating to the "National
Instruments\LabVIEW2009\Targets\NI\NXT\NXTToolkit"
oh, i see why you might be confused. This directory is probably easy to
find if I've installed the FTC toolkit. How do I do that?
10-01-2010
02:54 PM
- last edited on
06-11-2026
12:16 PM
by
Content Cleaner
You should install LabVIEW Education Edition 2009 using the media that ships with the FTC kit. Please let us know if you have not done that. There is also instructions for where to download and install the FTC toolkit on the packaging for this media. Basically it will send you to this download page.
Also, the examples for FTC do not exist in the "National Instruments\LabVIEW2009\Targets\NI\NXT\NXTToolkit" location. Instead they will be found at "C:\Program Files\National Instruments\LabVIEW 2009\examples\FTC Toolkit" after you install the FTC Toolkit.
I hope this helps. Let us know if you have more questions.
10-01-2010 04:22 PM
