Academic Hardware Products (myDAQ, myRIO)
61202 error in custom bitfile reference plus default PWM FPGA and other references
Hello community.
I am trying to develop a speed control algorithm for a DC motor using PWM modules, analog inputs for the curren sense and digital outputs for the output enable pins of the power integrated circuits. I have also created an FPGA vi that allows to measure the speed through the encoder. How can I open multiple references to PWM modules and others and open a reference to my FPGA vi using loops in parallel? Or how can I create my custom FPGA vi to use these modules in parallel? What would be the best solution?
PS: My FPGA vi works fine when runs alone.
(3,217 Views)
Accepted by jecks_00
This worked for me. It's the best option make a custom FPGA vi based on the labview default FPGA one. It's a good tutorial.
https://forums.ni.com/t5/Academic-Hardware-Products-myDAQ/modification-of-FPGA-personailty/td-p/3666...
(3,164 Views)
