Academic Hardware Products (myDAQ, myRIO)
Are NI Elvis and Multisim interactive without labview
If a circuit is set up and tested using Elvis, are the results of an output displayed in Multisim or in Labview?  If I want to tweak my Multisim simulation to match the output of the circuit set up in Elvis, can this be done in real time?      I know that TINA can do this with their hardware/software.     Thanks
(6,409 Views)
Accepted by jweaver
jweaver -
You can display the measurements in Multisim or LabVIEW.  With NI ELVIS, you can use 12 stand alone software instruments by installing the driver (DMM, FGEN, Oscope, ect).  The instruments are build using LabVIEW.  You can access these same instruments in the Multisim environment and compare the Multisim circuit simulation to the live hardware measurement in real time.  I'm including a tutorial describing how to do this using NI myDAQ hardware.  The steps are the same for NI ELVIS.
If you want to create a custom application beyond the 12 instruments, you can program the instruments in the LabVIEW programming environment.
» Using myDAQ with NI Multisim Circuit Design Software
(6,395 Views)
