Academic Hardware Products (myDAQ, myRIO)
DAQ Assistant not finding Supported Devices
I'm a new Labview user and am trying to acquire some data from some force sensors connected to a NI USB-6009 DAQ. After installing the drivers, I tried plugging the force sensor in to the DAQ (I'm using a Flexiforce force sensor). The ground is in to the GND plug, the positive and negative are wired to the AI0 and AI4 screw plugs. I placed a "DAQ Assistant" block on a new VI and tried to configure it for a Force Sensor. Unfortunately, the DAQ Assistant is saying that there are "No supported devices found" (Acquire Signals -> Analog Input -> Force -> ). I checked in the Measurement and Automation Explored and the DAQ is recognized/ listed there. I would appreciate any suggestions and help. Thank you.
(6,268 Views)
It appears that this issue is being handled here.
Best Regards,
Thomas B.
(6,252 Views)
