Academic Hardware Products (myDAQ, myRIO)
Switching between digital input and output
I am using ELVIS II to develop a protopyte of product. The key thing is that I have to use one DIO port of ELVIS II to perform both read and write data. After sending data out of this port I have to read another data package back on the same port. The time to switch between reading and writing as short as possible (say about nanosecond or microsecond). I am also write a small software to measure the switching time of ELVIS II and I found that it take about 6 milisecond. This is not a good thing for my application.
Is there any way to speed the swtiching time up?
I alos attach the simple software that I use the measure the switch time of ELVIS.
(5,885 Views)
Hi zeroxx,
That kind of speed is definitely expected behavior when you are actually creating a channel each time for the read and write. If you had them on separate lines and created the channels beforehand it would run faster.
TimC
(5,867 Views)
