Academic Hardware Products (myDAQ, myRIO)
how to generate 3 phase sine wave to output on ELVIS
Hi .I need to make a star or delta connected circuit on ELVIS board.2 make this circuit I need 3 wave generator( with 120 phase shift) and one common ground
and because the ELVIS function generator can only generate one wave I decided to generate countionuos sine wave in Labview.
Now I can generate 2 continuis sine wave in labview and output them on the analog outputs of ELVIS.Ao-0 and A0-1
but I dont know what to do for the third signal.the elvis board just has 2 analouge output and when I use  Ao-0 and A0-1 I cant use ELVIS function generator after that.so would u please help me on this problem.how can I output 3 contious sine wave in Elvis.I have attached my VI to this post
(7,414 Views)
Hey,
Unfortunately there is no way to generate this 3rd wave from the computer - the ELVIS was designed with only two AO ports as there are a selection of DAQ cards which can interface to it which only have two analogue outputs. The only option I can think of is that you could perhaps use the breadboarding ability of NI Elvis to create some circuitry to generate the wave.
Kind regards,
Dominic Walker
Cardiff University
Electrical and Electronic Engineering Student
(7,370 Views)
Hi, I am also having some problem in generating two signals from two AO. Could you please tell me how to generate two different signals from two AO. I have attached vi which generate square wave from one AO 0. I need the inverted signal in AO 1.
(6,213 Views)
