Academic Hardware Products (myDAQ, myRIO)
FPGA board not recognized by PC, doesn't install drivers
Very well....I did not know it was that involved.  Because our instructor loaded the entire class without a hitch, I took it for granted that it is a unique driver regardless of the all the variables you mentioned.  To the point; I have the following:
Operating System : Widows-7 Professional SP1 - 64 BIT
LAB VIEW : Educational Edition - Version : 12.0.0
Digital Board (FPGA - Board) : 193426B-01L - Rev C.0
I do wish to run it in Multisim Mode, So, it seems that I will need "FPGA - Module" as well as the "Driver".
Please advice the Software Versions and Rev. Level etc..etc...that I have to have, where to find them and the order of installation (Which Software, then which then when to connect to the P.C.), or a brief instructions.  I appreciate all the help I can get.
Thanks.
(6,136 Views)
If you want to program the DEFB from Multisim, you can download Xilinx ISE WebPACK 13.4.  This software is free and you can get if from here:
http://www.xilinx.com/support/download/index.htm
When you install this software, make sure you select the WebPACK edition during this installation otherwise it will install the professional version.
Tien P.
(6,126 Views)
