Academic Hardware Products (myDAQ, myRIO)
ELVIS 14.0: Disable / Uninstall Web Services
It seems like my NI Elvis 14.0 installation also installed NI Web Services, which is taking up port 8080 on my computer (which is a very commonly used port for web development...). Seeing as I am using Elvis purely for interfacing with my myDAQ, I doubt I'll ever use the web services. Any way to uninstall/disable them? I saw a few help articles about disabling using the manager at localhost:3580, but for some reason I always get redirected to localhost:3582 which gives me a "404 - Not Found" error (which means that Web Services is also taking up ports 3580 and 3582...scary!). Any tips?
(7,743 Views)
Hi woojoo666,
It looks like someone else on the forums has encountered a similar problem and found a solution to it.
https://forums.ni.com/t5/LabVIEW/Turn-Off-NI-Application-Web-Server/td-p/3066695
Hope this helps!
Best Regards,
https://www.linkedin.com/in/trentweaver
(7,720 Views)
Hi Trent,
When I tried to connect to port 3582 I get a 404 error:
However, clearly NI Web Services is using that port:
Am I forgetting to do something, like start up the web services or disable a firewall?
(7,708 Views)
Hi woojoo666,
You can also try getting to the Web Server Configuration page by opening LabVIEW and navigating to:
Tools » Options » Web Server » Configure Web Application Server
Do you still get the 404 error when accessing it this way?
(7,686 Views)
The weird thing is I never installed labview. I installed ELVIS 14.0 purely so I could use the myDAQ, so I don't know where I got this extra functionality that seems to be part of LabView and not ELVIS.
(7,669 Views)
