03-31-2008 04:44 AM
I have a simple question, are the DSUB pins connected to any I/O lines or not?
Basically I need to implement a RS-232 communication, so, can I use the DSUB
directly or do I need to use de D0<0...7> and connect it to the DSUB?
Thanks.
Solved! Go to Solution.
04-03-2008 03:26 AM
11-17-2010 09:44 PM
we just got new Elvis 2 + in our university. I tried to connect the func gen and oscilloscope together such that my labview will generate signal and will read through oscilloscope and will display it in graph or chart. But when I give a square signal, the oscilloscope reads the signal but doesn't show the signal properly in graph. Rather the signal can be displayed in chart but it looks like somebody has multiplied impulse function to my square. The image of the chart is uploaded and also the image of the program. Please help.
Sandip
11-17-2010 09:52 PM
How can anyone possibly know what you have done just by those images? All of the coniguration is hidden in two expess VIs, Even the settings you pass in are hidden.
11-17-2010 09:58 PM
Check the front pannel image...
Sandip
