Academic Hardware Products (myDAQ, myRIO)
Found no MyRIO when running Installation Wizard
I have previously used myRIO-1900 with no problems. A few weeks back I installed the Vision Acquisition Software and the Vision Development Module, and for some reason I could no longer connect to myRIO.
I have uninstalled everything and reinstalled in the following in order:
  1.  Labview 2016 32 bit
  2.  NI-DAQmx 16.0.1
  3.  Labview 2016 Real-Time Module - English
  4. Labview 2016 FPGA Module
  5. Labview 2016 myRIO toolkit
I can find my device under NI MAX, and have already followed and tried the advice from this post: http://digital.ni.com/public.nsf/allkb/EF7E903F1ABC567286257F9C0076D9E8, but with no luck.
I have tried the myRIO on another computer, and it worked fine there.
It seems like everything works as it should, except when trying to run the installation wizard. Hope you can help.
Martin
(3,070 Views)
Hello Martin,
Could you please send screen shots of all installed software under both My System, and MyRIO in NI MAX?
Have you attempted to try all the USB ports on your PC, including the ones at the back?
Are you using the same USB cable for both the working and non-working computers?
Sas
(2,993 Views)
