Academic Hardware Products (myDAQ, myRIO)
myRIO Project Error
I have created a project in LabVIEW for the myRIO before. When I come back to create a new one I follow the same procedure: New Project --> myRIO Project, then I name the project and give a save location. Next, the device name should show up in the Select Target window, but instead a pop-up file browser comes up asking me to select an Agent VI that doesn't exist. Also, the original VI's created in the first project will not connect to the myRIO. Any advice or help for moving forward would be greatly appreciated.
(2,894 Views)
Hi jmcg,
Has anything happened to the computer between myRIO project templates working and not working? Any software changes, hardware changes, power outages? I found a similar thread which was solved when the user reinstalled the software (LabVIEW, Real-Time module, myRIO toolkit). Solved: Re: MyRIO templates issues
Josh
(2,860 Views)
