Academic Hardware Products (myDAQ, myRIO)
Hardware Digital Trigger using DAQ Assistant Express VI
I would like to write a digitally triggered oscilloscope LabVIEW program for a myDAQ using the DAQmx Express VI DAQ Assistant. However, when using the Triggering tab in DAQ Assistant, the Digital Trigger option is greyed out. Is it possible to hardware trigger a myDAQ, possibly using a Digital I/O line?
(8,318 Views)
Hey John,
It may be greyed out because you may have the Generation Mode set to 1 Sample (On Demand).  If you check in Configuration Tab under Timing Settings, try setting the Generation Mode to 1 Sample (HW Timed), N Samples, or Continuous Samples.
Jake
Jake G.
(8,310 Views)
Jake--
 I have N Samples selected in DAQ Assistant and am not able to choose Digital Edge Triggering without getting an error message. I was hoping there was some work-around for this, possibly by using the digital inputs. Thanks for your help.
John
(8,293 Views)
Hi John,
Personally I would avoid using the daq assistant for this type of work. This article should help get you started with manually triggering the device.
Cheers!
TJ G
(8,287 Views)
TJG--
 This summer, I'm running a workshop for instructional lab instructors based on a LabVIEW book I wrote which implements the DAQ Assistant in earlier chapter (DAQmx is covered in later chapters). Many of the participants are looking for low-cost ways to include LabVIEW in their lab courses, so I'm including work with the myDAQ during the workshop. MyDAQ does everything I need, except seems to lack hardware triggering of the analog input operation (unfortunately).
(8,279 Views)
Hi John,
I just went and grabbed a myDAQ to verify this behavior, and creating a digital trigger on the myDAQ is indeed impossible through the DAQ Assistant. I get the following error:
   Error -200077 occurred at DAQ Assistant
   Possible Reason(s):
   Requested value is not a supported value for this property.
   Property: Start.TrigType
   You Have Requested: Digital Edge
   You Can Select: None
This is because of the limited functionality of the myDAQ, which is unfortunate... Sorry I couldn't be of more help
Cheers!
TJ G
(8,270 Views)
TJG--
 Thanks for verifying with your unit. Hope digital triggering is included on future version of myDAQ
(8,268 Views)
