03-22-2011 05:14 PM
I would like to write a digitally triggered oscilloscope LabVIEW program for a myDAQ using the DAQmx Express VI DAQ Assistant. However, when using the Triggering tab in DAQ Assistant, the Digital Trigger option is greyed out. Is it possible to hardware trigger a myDAQ, possibly using a Digital I/O line?
03-23-2011 05:05 PM
Hey John,
It may be greyed out because you may have the Generation Mode set to 1 Sample (On Demand). If you check in Configuration Tab under Timing Settings, try setting the Generation Mode to 1 Sample (HW Timed), N Samples, or Continuous Samples.
Jake
04-04-2011 03:29 PM
Jake--
I have N Samples selected in DAQ Assistant and am not able to choose Digital Edge Triggering without getting an error message. I was hoping there was some work-around for this, possibly by using the digital inputs. Thanks for your help.
John
04-05-2011 01:35 PM - edited 04-05-2011 01:40 PM
Hi John,
Personally I would avoid using the daq assistant for this type of work. This article should help get you started with manually triggering the device.
04-06-2011 02:45 PM
TJG--
This summer, I'm running a workshop for instructional lab instructors based on a LabVIEW book I wrote which implements the DAQ Assistant in earlier chapter (DAQmx is covered in later chapters). Many of the participants are looking for low-cost ways to include LabVIEW in their lab courses, so I'm including work with the myDAQ during the workshop. MyDAQ does everything I need, except seems to lack hardware triggering of the analog input operation (unfortunately).
04-07-2011 04:20 PM
Hi John,
I just went and grabbed a myDAQ to verify this behavior, and creating a digital trigger on the myDAQ is indeed impossible through the DAQ Assistant. I get the following error:
Error -200077 occurred at DAQ
Assistant
Possible Reason(s):
Requested value
is not a supported value for this property.
Property:
Start.TrigType
You Have Requested: Digital Edge
You Can
Select: None
This is because of the limited functionality of the myDAQ, which is unfortunate... Sorry I couldn't be of more help
04-07-2011 04:40 PM
TJG--
Thanks for verifying with your unit. Hope digital triggering is included on future version of myDAQ
