Academic Hardware Products (myDAQ, myRIO)
How can I acquire and analyse signals from analog input on myRIO?
I tried to acquire a signal from nerve via analog input. I was able to get something on labview but it is a value instead of a waveform. How can acquire the signal and analyse it for peak to peak?
(5,773 Views)
What did you try so far?
How often were you acquiring the data?  Even waveforms are "just a value" when they are read.  They don't become waveforms until you merge a lot of readings together.
Have you looked at the myRIO starter guide?  http://www.ni.com/white-paper/14621/en/
(5,765 Views)
