Academic Hardware Products (myDAQ, myRIO)
How to fix admissible limits for a measurement
Hello guys,
I am supposed to develop a test bench with Labwindows CVI.I have several current measurements to do. But the problem is that I haven't the limits of each measurement (min acceptable value, min acceptable value) .So I should find that by myself. I heard about the Gage R&R method but I don't have a big idea about it: smiley sad: .Can you help me please.
(5,880 Views)
MAD_MADRIDISTA,
Thank you for your post, albeit slightly cryptic. As I understand it Gauge R&R is a statistical analysis method for measuring the overall precision of a measurement process that already exists. If you could perhaps explain a little bit more about what types of measurements you are in need of making and as well as what version of CVI and any hardware you are using. Also if you could please try to be a little more descriptive with the problem you are having I would be happy to further assist you.
Applications/Systems/Test
National Instruments | AWR Group
(5,870 Views)
