Academic Hardware Products (myDAQ, myRIO)
The software doesn't detect my ni daq help.
So I was given this. http://sine.ni.com/nips/cds/view/p/lang/en/nid/1041, then I dl the software from this site. http://joule.ni.com/nidu/cds/view/p/id/4240/lang/en.
I open up the software expecting 6070E to show up but it didn't. It did however ask me to "create" but when I click that and select DAQ it takes forever to search. So my conclusion is that my 6070E is not picked up by the software. Can anyone help me on this issue? Am I doing something wrong?
Thanks.
(6,536 Views)
The latest DAQmx supporting PCI-6070E is DAQmx 9.2.2, https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html#288334. Hence, you need to uninstall DAQmx, and install this old version. Unfortunately, DAQmx 9.2.2 supports up to LabVIEW 2010. If you use later LabVIEW version, you also need to downgrade it or updating your DAQ card.
(6,532 Views)
Thank you very much.
(6,529 Views)
I still didn't detect anything. There's 5 columns when I open the program
data neighborhood
device and interface
scales
software
I go to device and interface -> create -> device and interface -> Network Ni-DAQmx devices. No device found.
(6,486 Views)
Some times it helps to reset and refresh your device and interface
Please access the following link and follow the listed steps even if you are not seeing the specific error.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8k8SAC&l=en-US
Luis S
Application Engineer
(6,476 Views)
