Academic Hardware Products (myDAQ, myRIO)
NI myRIO unable to detect device driver
Im trying to connect myRIO using my laptop, right now i'm having difficulty to find the correct driver for myRIO. I did installed the software suit myRIO and driver. But somehow I still don't know how to locate the right files for the device driver.
http://sine.ni.com/psp/app/doc/p/id/psp-1166/lang/en
(3,375 Views)
Hello fendywoo,
Can you use NI MAX to look for the myRIO? If you can't find it under your PC drivers, you can take a look under "Remote systems."
Messenger2
If someone's answer helped you find a solution or provided insight into an issue, the best way to show your appreciation and acknowledgement is by giving them a kudo or marking their reply as a solution.
(524 Views)
