Academic Hardware Products (myDAQ, myRIO)
myRIO wifi connection
Hello
i am not able to configure the myRIO for the wireless comm and even though im using firefox browser im not able to see options that are used for the config of the myRIO wifi
(1,562 Views)
Hello, sathvikum.
I'm sorry I didn't see this earlier.  I have managed to get WiFi to work with the myRIO, but it isn't always easy, and with the changing status of Microsoft and NI networking components, I'd have to do some "experiments" to figure out how to "find" the myRIO with the current Windows 10 software and current LabVIEW 2019 or 2021 (32-bit) LabVIEW installations.
There are some limitations with the WiFi connection.  If you are still interested in exploring setting it up, respond to this post.
If you are not @sathvikum, please do not "hijack" this thread with a "Help me, too!" post.  Start your own Topic, and explain what you've tried, what software you are running, what experience you have with the myRIO, what software you've installed, and how experienced you are with LabVIEW Real-Time.
Bob Schor
(1,285 Views)
I can provide you with the following troubleshooting steps to help you setup the wireless communication in your myRIO:
1. Enabling the myRIO wifi module:
    - Connect your myRIO via USB
    - OPen NI MAX on your PC
    - Find the device under "Remote Systems"
    - Go to the 'Network Settings' tab and check if the WiFi/WLAN interface is enabled (enable it if it is disabled)
2. Restart the device after enabling the WiFi interface and then revisit the Web UI (172.22.11.2)
3. Also try temporarily using Chrome or Edge browser if Firefox fails to render the advanced configuration
Please do try the above steps and revert back with your results.
Thank you
(637 Views)
