11-30-2012 05:54 PM
I am real new to Labview and I thought this would be a simple project to help me with the learning process.
I want to build a test fixture for the Pinball machine pcbs. I have a number of them in storage from different manufactures. I think most of this is just going to be inputing a closed switch message to either the lamp matrix or the solinoid drivers and then monitoring the outputs to see if the lamp light or solinoid fired. This is where I want to start.
Could I get an idea and overview of the hardware and basic Labview software approach you would use to do this?
I have a PCI-6035E and a PCI-6534.
Is there some hardware that would make this easier to create or will I need to create a test jig to to buffer the signals before going into the PCI cards?
I am just looking for some general ideas on how to approach this.
Kevin
12-03-2012
04:27 PM
- last edited on
10-14-2024
10:00 AM
by
Content Cleaner
Hello uriahsky,
I would like to point you toward some helpful links in finding common LabVIEW architectures as well as how to utilize the DAQ resources you've mentioned below. I would recommend that you also browse through the available LabVIEW examples as a getting started point for a new application in which you may then use DAQmx functions (highlighted in the getting started link below) to then control your hardware.
https://learn.ni.com/learn/article/labview-tutorial (Introduction to NI LabVIEW)
https://www.ni.com/en/support/documentation/supplemental/16/simple-state-machine-template-documentat... (Using a State Machine (Event Driven) Architecture)
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1r9CAA&l=en-US (Application Design Patterns: Master/Slave)
https://www.ni.com/en/support/documentation/supplemental/21/producer-consumer-architecture-in-labvie... (Application Design Patterns: Producer/Consumer)
https://www.ni.com/en/support/documentation/supplemental/06/getting-started-with-ni-daqmx--main-page... (Getting Started with NI-DAQmx: Main Page)
