Academic Hardware Products (myDAQ, myRIO)
Please Help - myRIO Bourns Absolute Encoder using SSI protocol
Hi all,
So I bought a Bourns EMS22A30 absolute encoder for measuring the pitch angle of a turbine blade (controlling the pitch of the last 1/3 of the blade length to control the speed of the blade). I've had very little experience with LabVIEW and myRIO outside of a short 4 hour introduction course - about as green as you can get!
The spec sheet for the EMS22A30 is here: https://www.bourns.com/pdfs/EMS22A.pdf
My issue is that it uses SSI communication protocol - which I have only just discovered is not used by the myRIO (it uses I2C and SPI). Is there any way that I can connect, program and use this with the myRIO? I'd really like to avoid wasting this money as to me this was a very expensive purchase!
Any and all help will be greatly appreciated!
All the best, Rhett
(4,045 Views)
Hi there,
Here is some information on SSI communication on FPGA, I'm not sure how this would work with myRIO though.
https://decibel.ni.com/content/docs/DOC-1095
I hope this helps!
(4,017 Views)
