Academic Hardware Products (myDAQ, myRIO)
Problems with USB device when using WindowsNT
my problem is that I want to use a simulator which can only be connected with USB to the computer.
I used the VISA Driver Development Wizard as discribed in this link (http://zone.ni.com/devzone/conceptd.nsf/webmain/6792BAB18242082786256DD7006B6416) and it didn't work.
I'm using Windows NT and VISA 3.1 and I read that it isn't possible to create a USB connection with VISA when using Windows NT. So my questions
1) is this right
2) Has someone a idea what I can do? I tried to use VISA USB Control and this also didn't work.
I hope I discribed my problem detailed enough. It's my first post.
Thanks for your responses
Joerg
(7,153 Views)
once again me
I've forgotten to discribe the problem.
When I've created the .inf file and I try to install the file, the message " installation failed" appears but a .pnf file was created.
Joerg
Message Edited by emmerte on 09-20-2006 03:50 AM
(7,153 Views)
As you can see in this table, USB is not supported by VISA under NT:
http://digital.ni.com/public.nsf/websearch/EE34F21ECC2BE01286256C52005D1A1F?OpenDocument
I would recommend to use Win2000 or XP. Using one of these OSes you could use this turorial  to create your VISA-driver:
http://zone.ni.com/devzone/devzoneweb.nsf/Opendoc?openagent&1D0DD81FF1448CAE86256D90006EE2B4
If it is not posssible to change the OS, you have to look for other ways of programming your usb-device. Check the web or the Microsoft site for help concerning Windows SDK and USB.
Hope this helps a little!
(7,140 Views)
