Academic Hardware Products (myDAQ, myRIO)
shutdown the pc using labview (*.vi)
i made a vi in which i want to use a labview function that shutdown the pc when call  it function.
any one who know plz tell me how to do it
(6,682 Views)
You would need to use the System Exec.VI that can be found on the function palette. Its located under Connectivity >> Libraries & Executables palette.
The specific command that you would need to use would be "shutdown".
You can test this command out by opening up the windows command windows (Start >> Run & type in "cmd"). Type "shutdown" to get more information on this command.
Chetan Kap
Application Engineering
(6,665 Views)
