‎10-28-2024 08:09 AM
Hello All,
I am trying to integrate my Thermistor with mu USB-6002 to read the temperature. As am also configuring A, B and C Values in NI Max still it shows -273.15 C as a temperature. Can anyone help me with the solution to get the exact temperature values in NI Max.
I am attaching my Circuit diagram here for reference. Do let me the know the solution.Connection Diagram and Datasheet
Thank you.
‎10-28-2024 08:17 AM
Ensure that DAQ's AIGND is connected to the +5V ground powering the thermistor. Please share your code to ensure you have setup the DAQ correctly.
‎10-30-2024 02:55 AM
Hey Santhosh,
I've shorted DAQ's AI GND and 5V GND, but still i am not getting the correct reading.
Regarding the code, I am testing this in NI MAX environment by creating the task.
Do we have any other solution for this?
‎11-04-2024 11:04 PM
Check with a multimeter to ensure the voltage across the thermistor is proportional to temperature.
