Academic Hardware Products (myDAQ, myRIO)
Thermistor reading show -273.15 Value in reading even after A, B, C Values based on datasheet.
Hello All,
I am trying to integrate my Thermistor with mu USB-6002 to read the temperature. As am also configuring A, B and C Values in NI Max still it shows -273.15 C as a temperature. Can anyone help me with the solution to get the exact temperature values in NI Max.
I am attaching my Circuit diagram here for reference. Do let me the know the solution.
Connection Diagram and DatasheetConnection Diagram and Datasheet
Thank you.
(1,269 Views)
Ensure that DAQ's AIGND is connected to the +5V ground powering the thermistor. Please share your code to ensure you have setup the DAQ correctly.
Santhosh
Soliton Technologies
(1,266 Views)
Hey Santhosh,
I've shorted DAQ's AI GND and 5V GND, but still i am not getting the correct reading.
Regarding the code, I am testing this in NI MAX environment by creating the task.
Do we have any other solution for this?
(1,233 Views)
Check with a multimeter to ensure the voltage across the thermistor is proportional to temperature.
Santhosh
(1,178 Views)
