Academic Hardware Products (myDAQ, myRIO)
Using myDAQ with LabVIEW 2012
Can LabVIEW 2012 use the myDAQ? When I run LabVIEW 2011 I can use the DAQ Assistant within LabVIEW, but on LabVIEW 2012 I do not see the DAQ Assistant Express VI. I saw the drivers do not support LabVIEW 2012 on the website, but was wondering if anyone knew of a way to use the myDAQ with the 2012 version. The myDAQ runs fine on my 2011 version, but my students are using the 2012 version and have had trouble getting it to work. I am hoping they do not have to all reinstall LabVIEW 2011.
Thanks in advance
Message 1 of 8
(8,769 Views)
Accepted by ryanc821
LabVIEW 2012 support was added with NI ELVISmx 4.4.  You can download and install the driver, which will install DAQmx 9.5.5 and ELVISmx 4.4 support for LabVIEW 2012, allowing you to use the DAQ Assistant and myDAQ in that version.
Donovan
Message 2 of 8
(8,752 Views)
Donovan, thank you
Message 3 of 8
(8,743 Views)
Donovan, thank you
Message 4 of 8
(8,740 Views)
I have DAQmx 9.6.2, Labview 2012 and Windows 7.  I have tried the user preferences to turn off notification.  DAQ assistant works, I can configure a channel and run it from within the task window, but as soon as I try to execute the task in LabView I get a message about the channel needing a sample rate. The channel has a sample rate assigned.
ELVIS tasks work and the debugging windows in MAX work, the tasks just won't run in LabView.
I just tested the same vi on an XP computer and LabView 2011 and it works fine.
Even the myDAQ troubleshooting utility gives this same error.  Do I need a different driver?
Message 5 of 8
(8,535 Views)
Have you installed NI ELVIS 4.4?
Applications Engineer
Message 6 of 8
(8,509 Views)
Yes.  The ELVIS tools seem to work fine.
I downloaded the 9.7 drivers to replace 9.6.2.  I will give that a try this evening.
Message 7 of 8
(8,501 Views)
The 9.7 drivers fixed my problem.
Message 8 of 8
(8,490 Views)
