Academic Hardware Products (myDAQ, myRIO)
What Kind of microcontroller is needed for alarm system with PIR sensors
Hi ! I'm student at Technical University Varna ,  Bulgaria . I'm interessted to create my own alarm system with Labview, but I'm not sure what kind of controller i need and what kind of PIR sensors.                  Thank You
(7,047 Views)
Hi xellos,
I'm not sure what you need, but if my feelings is right, than what you  want to do is sort of motion detector based on PIR sensor and some ucontroller. It this is what you need, than once again, such a question is rather suitable for other discussion forums, like LabVIEW Embedded.
However, in general you can go for ARM or Blackfin when thinking about embedded platform. See following links to get more ingormation on ARM and Blackfin with LabVIEW:
NI LabVIEW Embedded Module for ARM Microcontrollers
NI LabVIEW Embedded Module for ADI Blackfin Processors Development Kit
With choosing sensor, I suggest simple googling - with relativly little effort you can find many sensors. And you can pick on specification and requirements you have (just to note, National Instruments is not producing and usualy not selling sensors).
Stefo
(7,028 Views)
Also posted here.
(6,973 Views)
I have USB 6501 Digital I/O Device and a LC 100PI PIR Motion Detector and i wanna connect them to take data from the sensor and use it in Labview the Digital Device  has lower input voltage and i'm worried about that because the output voltage of the sensor is higher
The Sensor Specifications are :
Detection Method : Quad(Four Element) PIR
Power Input : 9.6 - 16 VDC
Current Draw : Standby 8mA Active 10mA
Compensation YES
Alarm Period 2sec
Alarm Output N.C 28VDC 0.1A with 27Ohm series protection resistor
Tamper Switch N.C 28VDC with 10Ohm series protection resistor
Warm Up period 60sec
RFI Protection 30V/m 10-1000MHz
Digital Device Spec : http://sine.ni.com/ds/app/doc/p/id/ds-135/lang/en
Thank You All for the Help !
(6,664 Views)
