05-25-2013 06:04 PM
Hi All,
I have recently installed LabVIEW 2012 and DAQmx 9.6 (and tried with higher version also) in my PC with Windows 7. I have measurement and automation explorer 5.4 version. I am trying to work with USB 6009 DAQ device. Everything looks compatible but when I try for self test of the DAQ, it fails. However, I used to use this device (since I purchased it last year) with other PC which has WindowsXP operating system and old version of LabVIEW 8.5.
All I can see with LabVIEW 2012 is a message "An error -88302 occured." and "This might be internal error."
If anyone has some idea to fix the problem, please let me know.
devkotaj
Solved! Go to Solution.
05-28-2013 09:03 AM
Hi devkotaj,
The USB 6009 device should run fine on Windows 7 with the software you listed. This sounds like a hardware configuraiton issue to me.
What are you trying to do when you receive error -88302? This error usually indicates a corrupt DAQmx driver, which can result from installing multiple versions of DAQmx on the same machine. Have you tried repairing your DAQmx installation? I might uninstall DAQmx from the control panel before attempting to install the latest driver. You can look at our recommenedd reinstall/uninstall procedure here.
I hope this helps!
Andy C.
Applications Engineering
05-29-2013 02:48 PM
It works, thank you.
