Academic Hardware Products (myDAQ, myRIO)
compatibility issue
Im fadz,
We are using LabVIEW 2013 and LabVIEW 2014 (both with full license), but when we are trying to connect with NI myRIO 2015 (after installed all the CD's provided with the hardware) seem that the labVIEW myRIO only run for evaluation. Do we need to install the NI myRIO with serial number?
I need confirmation whether this NI myRIO 2015 can be use with LabVIEW 2013/2014 or not? What if, we have the academic license for 2013. Can it run with NI myRIO 2015?
Thank You,
Fadz
(4,217 Views)
@fadz_pinky wrote:
Im fadz,
 In order to use NI MYRIO 2015 you need to have active license for 2015 LabVIEW
https://www.ni.com/en/support/documentation/supplemental/13/required-and-optional-software-to-progra...
View the link above to find all the supported software. Normally MYRIO comes with a seperate License to use with LabVIEW check it out in your bundle.
Kudos Welcome 🙂
Certified LabVIEW Developer
Best LabVIEW Programmer @NIDAYS 2015
(4,172 Views)
Thanks for you response. Its really helpSmiley Happy
(4,150 Views)
