Academic Hardware Products (myDAQ, myRIO)
delay in a signal acquisition ( number of samples)
hello.
i 'm working with a NI myDAQ, I acquire teh signal without problem, but i need generate a delay in this signal, but no referent to the time, i need that is referent to the number of samples, I've been thinking in do this with some assistant or VI but i find nothing, my another idea is do this with a "index array" i put my signal in a array and make all that i need.
i need this for to make a difference equation.
thanks for the answer, really i need help.
(6,213 Views)
after some hours i can do this, only i use a a vi delay values, with this vi i can take the discrete signal with the delay than i want, this number correspond to the number of samples that i want, is so easy.
grettings from colombia.
(6,204 Views)
Duplicated post. Please refer to http://forums.ni.com/t5/LabVIEW/delay-in-a-signal-acquisition-number-of-samples/m-p/1723298
Please, attach your VI in the link above!
Thank you!
Felipe Flores
Technical Support Engineer
(6,076 Views)
sorry, now you can find the answer in the other forum.
grettings.
(6,072 Views)
