Academic Hardware Products (myDAQ, myRIO)
generate four analog outputs (square wave) using USB-Xseries
I am using a USB X -series with 4 analog outputs channels. I am trying to generate 4 square waves from 4 different channels. Please see attached image for detail. I am fairly new with LabView
(5,922 Views)
I don't think that this post will get many responses in this thread as you are not using ELVIS, myDAQ, or myRIO.  If you could repost this question here:
http://forums.ni.com/t5/Multifunction-DAQ/bd-p/250
I think you will have better luck with responses in this board.  Also include the name of the X series card that you are using.
Thanks!
Jon F.
Technical Support Engineer
(5,902 Views)
Thank you
(5,894 Views)
