Academic Hardware Products (myDAQ, myRIO)
how to play a sound saved in myRIO
 How could I call a file saved at usr/local/sbin in myRIO and send it to play? Thanks...
Message 1 of 15
(10,657 Views)
Gdblombardi,
Because the audio out expects a series of voltage levels you would need to correlate that saved sound file to an array of voltage levels to send to that output.  I do not know how or if you can read a sound file and correlate that to analog voltages so the only way I see of doing this is reading a sound file on your host PC and sending the waveform output to the audio out on the myRIO.
Message 2 of 15
(10,638 Views)
Accepted by gdblombardi
I did this way. I transformed the sound sample into an array (Sound Sample) and in another VI I read this sample (Ring Creator). It is working fine.
Message 3 of 15
(10,474 Views)
Thanks for posting your solution for us to see.
Is the sound sample.vi being used on the myRIO or are you using that VI on the host and sending the numeric array to the myRIO?
Message 4 of 15
(10,466 Views)
I am pasting the arrays that I need in the myRio. Some tools in the SoundSample.VI don`t work in Rio projects. Once the array is pasted I don`t need the SoundSampl.VI again unless I want to change the tones. Moreover, it is necessary to adjust the output frequency for each sample.
Message 5 of 15
(10,461 Views)
Awesome thanks for the help
Message 6 of 15
(8,087 Views)
Can you please help me out with this same topic. I am new to myrio and LabVIEW. So if you could do the program for me, it would be a great help
Message 7 of 15
(6,788 Views)
Hi Ashutoshsignh,
Did the above solution not work for you? Did you receive errors or anything like that? We won't write code for you, but we can help you out with ideas for code structure or any roadblocks you run into.
Nick
Message 8 of 15
(6,761 Views)
Hey
I tried doing it. Buy it didn't work.
Actually I have to integrate this program to an existing project and I have done that in Normal myrio project and not in myrio fpga project. So I am not able to do the program on my own. Please help me....
Thank you
Message 9 of 15
(6,754 Views)
Can you be more specific about what didn't work? Did any errors pop up? Are you seeing an unexpected result?
As Nick said, we cannot write the code for you, but will assist as best as we can on specific technical issues.
Angela L.
Message 10 of 15
(6,744 Views)
