Academic Hardware Products (myDAQ, myRIO)
i2c using MyRio
I want to use the I2C myRio. To make things easier, I'm currently working on the integration of MCP9808 a simple Thermometer.
I guess i created the easiest I2C-VI you can imagine an it doesn't work. It would be nice if you woul have look at it.
The address is 19. I connected A0 to the 3V.
(7,397 Views)
Adding attachments
(7,396 Views)
After i changed the slave adress to hex there is no failure code anymore. Now i want to read out the actual data.
Anybody a idea how to do that?
(7,383 Views)
Nice i Solved my problem by my self 😃
It`s not really finished and there a probably some things to optimise but it works.
(7,346 Views)
Accepted by topic author Maloya
(7,345 Views)
